what size heater for a MF 695 ?
Bigplumbs
7 Nov 2015
UK
Me too, three vents in all (2 lower cabins + heads) on one diesel heater. Just be aware that adjusting the outlets to reduce flow in desired areas will affect the back pressure in the ducting and potentially make the heater stop with an error code (overheating). Ducting increases the back pressure (diameter + distance + number of bends + vents,.)
My upper cabin has it's own diesel heater with very short ducting and one vent - never fails.
All those little bits you speak of are easily available on ebay
freddyuk
2 Sep 2012
True - I left the furthest outlet (front cabin) with open outlet to avoid this. As I fitted a shower on the rear deck (you cannot have a decent shower in the heads) I need to fit a butterfly outlet here for showering but did not want to heat it if the canopy was off or we were inside. It has a spray cover fitted to keep any rain out as well. Being the first outlet it is the hottest so ideal to heat the rear deck with canopy on.
paradave
12 Dec 2019
Do you guys overnight with these on? Our Eber is pretty loud and I’m pretty sure would annoy us / neighbours if it were on all night.
Freddy - love the sound of the additional shower on your 805. Any pics you could share?
ChromeDome
25 Sep 2020
We aim to be in marinas over night, with shore power available:
For peace at night I went for an Adax black glass panel. Wi-fi enabled, accurate temperature control (not only on/off) and then some. Really steady temperature, completely silent
IP24 classed, suitable for wet (bath) rooms
SWMBO loves it - and happy wife =happy life :rolleyes:
freddyuk
2 Sep 2012
Maybe I should do a new thread for this as it is specific to the 805. I will get some pics done.
