Sticky Fingers
Maxi 1100?
Maxi 1100?
The Dufour does look like a serious contender.
One oddity is that they seem only to have one pair of winches in the cockpit and I would have expected two pairs on a performance boat - but at least they are well positioned to allow the helm to trim the Genoa.
The winch position I love - for short handed sailing it is important that the helm can adjust all sheets from the helm position and so many boats have the primaries 6 feet away - often having to negotiate an over-sized wheel in the process. The downside is that the trimmer will normally be forward of the wheel so will tend to be operating the winch facing the wrong wayWhy would you expect 2 pairs? Unless you're trimming the main with winches you only need one.
The winches aft was something that I was initially sceptical about, but in fact came to love as it meant I could tweak away to my heart's content without disturbing the family who's notions of sailing were either to sleep or read books....
I am used to two pairs of winches in the cockpit - typically the primaries for the genoa sheets and spinnaker guys and the secondaries for the spinnaker sheets. The GS for example has a pair of primaries forward in the cockpit and the secondaries close to the helm position that could be used for Genoa sheets when sailing short handed.
Dehler 39.
What about a Sigma 400 or 41 or even a 38.
Ah - I'm clearly an old fashioned sort of guy - my halyard winches are on the mastThe aft winches on the GS are for the main sheet, what is known as the German system. You can just about make it out in this picture.
It's been standard for as long as I've been sailing to lead the spinnaker sheets to the halyard winches. I haven't come across a boat with separate spinnaker winches aft for years.
Ah - I'm clearly an old fashioned sort of guy - my halyard winches are on the mast![]()
Bit of thread drift...
I really can't get the hang on the German system - It drives me nuts.
Putting a gybe in with that setup is an exercise in winch dancing, especially as the main sheet slack is generally on the wrong side.
Reefing also tends to be some what slower - I'd definitely not expect to use the German system when racing...?
Am I missing something?!
Have you sailed with a well set up German mainsheet system? Ours is great. Mainsheet is right next to helm so easy to handle singlehanded.
Do need to winch in a bit of rope for windy gybe but no issue. And can’t see any reason why would make any difference reefing or unreefing (just for sport I timed my last efforts, reefing 3 minutes in total including rope tidy up, with sail not filling for under 60 seconds, unreefing took a couple of minutes longer to pull out reef lines as was doing solo).
Don't understand why reefing would be slower? You just ease sheet, reef, then winch it back in surely? Why is that slower?
Most crews racing with it tend to splice the sheet into a continuous line, so no need to worry about having all the rope on one side or not. And they then use the mast man to "bounce the As" to bring it in quickly - so pulling hard at the part of the sheet running from the gooseneck to the block on the side deck whilst the trimmer tails. Either through a gybe (if not just chucking the boom over) or at the bottom mark.
What I would do gybing in cruising mode would just be to do the work on one winch, so winch in and then take the sheet out of the self tailer, gybe the boat and ease on the same winch. There's no real need to ease the windward sheet. In fact, once you've spliced the rope to be continuous a lot of trimmers (when they want continuous sheet adjustment - on a reach for example) will have the leeward sheet out of the self tailer, and will be easing that and grinding the windward winch when they want to trim on. One hand to ease, one to trim on basically.
Or they just detail one of the "lesser" crew to grind for them...
So some people have suggested a Dufour 40, which is a nice boat, but will slam in a sea way.
I’d be very frustrated without a pair of winches either side and miss a more racing oriented boat with more.
For example I want to reef and have one winch for Genoa halyard leaving me just one winch for mainsheet, main halyard and the reefing line on that side. The other side in that scenario starts with a pair of unused winches and may have the vang on one briefly.
