What oil to use KAD32
pau1gray
8 Oct 2006
Plymouth
www.owlwise.co.uk
I have a KAD32 that is a little low on oil and could do with a bit of a top up, then again maybe need a complete oil change and filter change.
What oil should I use? Volvo say 10W/40 VDS or CD and about ?9? litres does ths sound right?
Is this a synthetic or mineral oil? And are there any alternatives without the Volvo label on (which seems to add a bit more!)
Any help greatly appreciated
This has been covered quite a bit recently. The general consensus seems to be that the Volvo stuff is not much dearer than other makes that meet the same spec. You can get cheaper oil that meets nearly all the spec but will usually not meet the VDS requirements.
9 ltrs of VP oil will cost around £50 at a guess. An alternative good make will cost around £35-40. As a once a year cost, I would be happy to pay the extra £10-15 and know that I definitely have the right oil.
My manual says 15W40 VDS2. If you want to stick with Volvo, go to your local Volvo Truck Service Centre. 20L of VDS2 £50.80 plus VAT part no 1161975
Having said that I was told VDS2 is not made any more and I should be using VDS3
FRAM Filters for KAD32 so you can buy from your local motorfactor
air CA4365,
oil PH 2861B
diesel P5770
