Swenns Dad
Maybe it’s a smoothing/spike/noise filter? Boat has a JRC RADAR so maybe it’s a filter??
The black domed thing is a transformer. I've worked with identical ones in different circumstances.
This means that it's a home made inverter or similar. Does the alternator have a separate connection through to the battery or does the main feed from the alternator to the batteries only go 'through' this unit?
Do not think it’s a regulator, not enough connections. No connection to alternator field ?Maybe it’s a smoothing/spike/noise filter? Boat has a JRC RADAR so maybe it’s a filter??
Again with a negative connection cannot see it being a diode splitter. And where is the connection to the second battery?
If anything, and it’s a big if, it might be some sort of filter/ suppression unit. The “transformer” might be an inductor (choke), although at the frequencies that are normally needed to be suppressed it would be a lot smaller. However the connection, in, out - and ground would make sense.
First post so please forgive if this arrives a little late !
Richard
Richard
I thought there was a slim possibility of it being a choke as well, but it would be so unusual to have a choke of that size that I discounted it and chose to treat that possibility as vanishingly small.
If it's a filter, then the DC resistance between the input and the output should be very very low. It can easily be checked with a multimeter.
Alternatively, just remove the device from the charging circuit and see if the alternator starts to work properly.
Another test would be to ensure that there is full battery volts appearing on the main output of the alternator when the engine is stopped. With the batteries 'on' the +Ve terminal on the alternator should be a direct connection straight through to the battery positive.
Good Luck with your quest & please let us know what you find out.
