What is the worst sailing or marine invention ever?
James_Calvert
6 Oct 2001
Some candidates:
The gadget I have on the end of a boathook with a line attached. It falls off as soon as it is anywhere near the mooring buoy eye or whatever you are trying to snap it onto. I know there are now better things available ....
Telescopic boathooks. I have the handle ends of two of them to date .... but I've given up buying them.
Those elastic sail tyers with hard plastic knobs on the end of them - if a flying knob doesn't get your eye, it gets your teeth or nose.
Greenheart
29 Dec 2010
Thanks for the warning, I've been lucky so far!
How about the powered primary winch? I remember watching totty breathlessly grinding away at each tack...mesmerising. Nowadays they just sit and smirk behind their shades. :(
snowleopard
Oxford
+1 for bungees with beads on the end. Lethal.
My vote is for spray hoods that have flexible windows. A few years use or a bit of spray and there's no way you can see through them to steer so you end up either having to lower them and get wet or stand on the side seats to see over the top.
Varnish work above deck. Re-coat twice a year or put up with flaking and black streaks.
Anything assembled using non-stainless screws or bolts.
DSC alarms you can't turn off without turning off the set.
Naval Officers.
Crew with deep pockets and short arms.
JumbleDuck
8 Aug 2013
SW Scotland
The bad inventions are, by definition really, the ones which weren't commercial successful and which therefore have no real impact on sailing. Unless this is one of those "what modern aspect of sailing do you deplore most?" threads.
