Beneteau381
I like pragmatic!No matter what safety precaution is suggested, there will always be a situation where having it will be more dangerous than not. It's a matter of risk assessment - which is more likely, an emergency need to get the sole up, or getting brained by a flying floorboard in a knockdown, and what's the likelihood of either event?
On my Catalac, I reckon the risk of flying floorboards is low - if they start flying around, I reckon my priority would be getting the hell out of Dodge, so I'm quite happy to rely on gravity to hold them in place. On a bluewater monohull or a sporty capsisible cat going offshore, my assessment would be different, and I'd like the boards to be held down. I would suggest that a sump with through hulls or transponders is vulnerable to sudden ingress of water than needs to be dealt with right now, so those expensive clips are probably worth the cost, the ones where edible and drinkable ballast is stored and have no holes in the GRP could be screwed down into the OP's inserts or similar, with a dedicated screwdriver living in a clip somewhere nearby, so it can be found when needed. I wouldn't screw them direct into wood or grp because regular removal and replacement means they'd get loose eventually.
