rafiki_
Included in my engine room check P.Interesting that the only mention of seacocks is for closing the head sink before going out.
I can only assume that nobody bother closing the engines ones after arrival...
Tut, tut.
Tut, tut.
Other than thy water maker which is not in use at the moment as I broke it I don’t touch sea cocks other than exercising them at random intervals.Included in my engine room check P.
I always closed my engine and gennie seacocks. They needed frequent exercising or they could stick. I had one jam shut a couple of years ago.Other than thy water maker which is not in use at the moment as I broke it I don’t touch sea cocks other than exercising them at random intervals.
When I had a trailer boat, the keys never left the ignition and the bung was only loosened to drain any water and done up immediately afterwards. Leaving keys at home and bungs out would be the most common fail of any trailer boat ownerBoat keys and bungs in,
Nothing worse than towing 3 and a half hours to go boating and with all the excitement you left the boat keys on the kitchen table, wife found this hilarious, however i did not!! Top of my list now hahaha
I also look in the fridge first. Then I can look forward to what will come laterFridge is cold...
It was stolen 3 times but we won’t mention that ?
Do you run your genny while plugged into shore power ?I don't think 1 check really makes much odds!
I do the following
- Engine room look ( I am only looking for something out of order like oil or water or blocked strainers. Oil I did every 3-4 days)
-close all doors, hatches and lock cupboards. If a long passage or rough move all suff that can fall like coffee makers etc.
- start engines, select helm, nav kit on, radio on, rudder central. If first trip since arrival test thruster and port / stud on both engines. Sufficient fuel, start gen if we want AC running or if the washing machine / dishwasher is on.
- remove cross lines, shore power, one bow line and one stern line. Bring in steps and mat if not coming back
- brief crew on what we are going to do to leave ( it varies if home berth, coming back, not coming back, wind etc- does not take long and everyone knows what is going on) . Tell kids to get off their iPad!
- stern line off, bow line off, out - fenders in
It is always the same, so it get done.
Shouldn’t matter should it?Do you run your genny while plugged into shore power ?
I read somewhere that you shouldn’t even have it plugged in if running the genny. Just wondered if it was trueShouldn’t matter should it?
surely you have a double pole switch to swap between genny and shorepower? Shore power/off/genny.
if the 2 ever saw each other electrically.......many sparks, death and fire.
Pre leaving the berth yes. It then flips to generator and the shore power lead will be removed a few minutes later. Likewise on return plug in, turn gen off and it flips to shore.Do you run your genny while plugged into shore power ?
Not that I know of. They are isolated by double pole contactors. On flipping back to shore if there is a lot of load you can trip shore power so I turn off ac compressors , turn off gen , then turn them back on again.I read somewhere that you shouldn’t even have it plugged in if running the genny. Just wondered if it was true
