What is the 1 check you always do
If I needed to send one I could go below and use the wired mic I suppose although if the boat was sinking or on fire that would be less appealing than risking the Bluetooth. I've also got a handheld VHF. I might get the wireless handset changed for a wired mic. Simrad radio by the way. I like the plotter a lot but this arrangement is weak.
Sounds like my RS40B. You should be able to set the radio to come on when it senses a power supply, this is how I have mine set up. I turn on the accessories power and on it comes (y)
Close the heads sink seacock. Otherwise when we’re close-hauled on port tack, the heads compartment gets an unplanned saltwater washdown.
Problem with that is that the NMEA power is on whilst the boat 12v is on. And I only want the radio on when we're prepping/under way, so I leave it turned off. I need to be able to turn it on from the helm.
Actually the list is long,
Unlock the liferaft
Unfurl the flag (amazed how many times I forget this)
Check the tender isn’t full of rain water
Check the engine
Unplug the electric
Untie the boat (or it will make your knots really tight)
and of course
Life jacket on dog
Apart from all the usual engine checks and checks round the boat, one thing I try always to do is to wind the wheel from lock to lock and check we've actually got steering. I also put the engine in gear fwd and ahead before casting off any lines to make sure we've got a propellor that's turning.
(Regarding the second one, I didn't do this once and after casting off and allowing us to be blown off the pontoon a few feet, I put the gear lever ahead and nothing happened. The person who did the engine checks (not me as it happens as we has a crew of twelve on board) anyway, this person had done the checks and hadn't noticed that the gearbox had fallen off the engine - enough to stop all drive. A sister boat pulled us out of the harbour so I could set sail.)
I forgot......Check no one from the Welsh Med is in the intended cruising area
except Seastoke
no danger of seeing him
or BruceK
he‘ll be broke down....
kwackers is welcome of course ?
I turn it on but with the volume right down, on my setup the remote volume is independent so that avoids the issue (one does however still get the occasional random DSC alarm).
Water coming out of exhaust + oil pressure up + gears engaging + bowthruster working - all before slipping berth.
Check for debris at the stern e.g. bits of floating wood etc, many years ago a piece wood caught the prop, lesson learnt. Also check steering and forward and reverse gear before casting off plus many other checks.
I don't think 1 check really makes much odds!
I do the following
- Engine room look ( I am only looking for something out of order like oil or water or blocked strainers. Oil I did every 3-4 days)
-close all doors, hatches and lock cupboards. If a long passage or rough move all suff that can fall like coffee makers etc.
- start engines, select helm, nav kit on, radio on, rudder central. If first trip since arrival test thruster and port / stud on both engines. Sufficient fuel, start gen if we want AC running or if the washing machine / dishwasher is on.
- remove cross lines, shore power, one bow line and one stern line. Bring in steps and mat if not coming back
- brief crew on what we are going to do to leave ( it varies if home berth, coming back, not coming back, wind etc- does not take long and everyone knows what is going on) . Tell kids to get off their iPad!
- stern line off, bow line off, out - fenders in
It is always the same, so it get done.
