What gas alarm?
VicS
13 Jul 2002
pvb
UK East Coast
Although it's tempting to buy the cheapest gas alarm, I wonder whether something which you obviously consider important should be bought on price, rather than reputation/quality.
Another consideration is that dedicated boat gas alarms can generally be connected to a solenoid valve, to isolate the gas supply automatically if a leak is detected.
fisherman
2 Dec 2005
Far S. Cornwall
This is needed for the MCA cert. They are notoriously intolerant of the FV wheelhouse environment, so not sure it will last. I only use the stove occasionally and the bottle is mounted outside the aft wheelhouse window, so I turn it off after every use.
VicMallows
25 Nov 2003
Emsworth, Chichester Hbr, UK
Lidl and Aldi occasionally have them on offer. CE marked, so must be up to certain standards.
I've had a LIDL one (about £12) for around 3yrs and it certainly detects any gas quickly enough if you are a bit slow lighting the cooker. Have also fitted them on a couple of boats which required coding. Power consumption is around 100mA so you may want to disconnect if boat is not in use (and gas is definitely disconnected!).
Vic
mhouse
27 Jan 2002
Here
Ive got the lidl one but beware, under some conditions i can hear the high pitched squell so have to turn it off and no 1 daughter cannot remain on board withit working !!!!
pappaecho
13 Oct 2004
S. Hampshire
I have a gas alarm fitted before I bought the boat. It works well, if I give it a whiff from a butane gas torch, as a quick test.
I have since see similar (tat?) on Ebay.
