Robin
Like all things, it just depends! The worst one is when the wind starts as light offshore one in very hot sunny weather, then gets cancelled by a very strong see breeze as the land really heats up during the day. The sea breeze starts more or less from SW or W then moves around to NW by sunset, N a bit later and then all that air that went inland starts to go home after midnight but this time added to the original land breeze. Sometimes it is very little more than a direction change but a few times we have seen F6 cause chaos amongst the hundreds of French boats who have little Brittany anchors, not enough chain or dumped in a heap and the anchors not dug in. Makes quite a fun party as long as you are in the (new) upwind position, something to aim for in defensive anchoring! We once had a S/S snubber hook made from 10mm bent rod straighten despite a rubber Gondolastik thingy in the snubber line - we now use cast S/S proper chain hooks! If it does happen it is relatively short lived and you lie to the waves and pitch, much better than rolling. The real problem is that where we see it most the fetch in a Vent Solaire is over 12 miles so the waves pick up if you are open to it, F6 or even much more is fine if the wind is offshore as the holding is good in hard sand.
It isn't something to get paranoid about but to be aware of. If you see lots of the locals dissappearing round the corner to another bay about sunset you might want to ask yourself why, sometimes it is just what they do, other times they might expect a vent solaire! We have often moved and it didn't happen and stayed when it did! It is very difficult to forecast, sometimes the French VHF forecast will predict the shift in the day from SW-W-NW-N but not get the last most important bit when it goes the extra bit to NE. The good news is you only get it in GOOD weather, if the weather is crap you don't get it, the winds are the same as back home around a low.
