What bedding compound for new acrylic hatch screen on dark hardwood?
Captain Crisp
1 Mar 2015
Hi all.
I need to attach my new acrylic hatch screen to its dark hardwood frame. What bedding compound would the panel recommend?
Many thanks!
Crisp
Tranona
10 Nov 2007
You can cut the seam in the highly unlikely event you would ever want to remove it intact. No reason to need to remove it other than replacing it in maybe 20 years time as I shall shortly be doing on a similar construction hatch where if necessary I will cut it off.
Poignard
23 Jul 2005
South London
Good stuff but very permanent
But not so permanent that it can't be cut with a knife, as Tranona points out; or with a padsaw.
My forehatch consists of a simple wooden frame with a piece of 12mm acrylic laid on top and held in place with woodscrews and cup washers. I think Captain Crisp's is likely to be similar.
To maintain an even thickness of CT1 I used small rubber o-rings; one around each woodscrew between the acylic and the frame.
If I ever need to remove the acrylic intact, all I have to do is remove the woodscrews and cut through the CT1 and the rubber o-rings.
[2574]
29 Nov 2002
I decided not to seal mine, I screwed it. Didn’t want to see the squished sealant from the outside:
PetiteFleur
29 Feb 2008
Suffolk
If you use Butyl tape, fit a stainless washer at each fixing point between the cabin and the acrylic, so the Butyl tape does not get squeezed out.
Poignard
23 Jul 2005
South London
I would only use butyl tape where there are mechanical fixings as it is not an a structural adhesive
Good point.
My forehatch is basically a 5-sided box with the acrylic sheet forming the fifth, and largest, side.
Being fixed with screws and an adhesive/sealant, it contributes greatly to the structural strength of the whole assembly.
