Akestor
I got sanding down to gelcoat ( dark green gelcoat-light green is gelshield) . Problem is that i discovered heavy osmosis above keel, with water not being under the gelcoat, but under the outer fiberglass lamination which for somereason was pigmented dark blue. So the vinegar water was trapped between the outer skin and the deeper white colored lamination, and this caused delamination between these layers. I grinded out all wet area and i will relaminate. I guess a sandblast would not have revealled all these as in some cases the outer blue lamination is 5- 8mm thick..
The areas were easily discoverd as they were slightly swollen and could push them with a screwdriver, then grinded until blue lamination was dry and not delaminated from white layer... i read about injecting epoxy in the delaminated area through holes, but then you go blind not knowing where the epoxy got, or were water is still trapped...
Any feeback is very welcomed!
