oGaryo
Be interested to know a bit more about your alarm etc Gary
A couple of years ago we thought someone was using our hot tub at our holiday home and eldest (who is niw a Master of Electronic Engineering) adapted an old webcam and mounted it above tne decking but didnt connext it to anything but he put a grain of wheat flashing led in the body of the camera so anyone looking at it thought it was live.
Dows you marina not have cctv covering the basin ? At ours they seem to have them everywhere and coupled to that we did hear the night watchman on his rounds at least twice a night. I thoughtsuch security would be facrored into your berthing costs ?
Can't give too much information regarding the alarm for hopefully obvious reasons. It's a standard car alarm with motion and door detectors with the vibration setting turned off and no immobiliser connections. You have to be careful what battery you connect it to too else supply fluctuations when the battery charger kicks in when you're not at the boat sets some of these car alarms off too. A separate battery may be required in some installations.
The GPS tracker is one of these hidden away behind a panel.. you just need to make sure you can top up the SIM card without needing to remove it. presuming you'd use a pay as you go sim card. Also, there's a setting that stops the repeat alert as that will use up all the credit in no time at all.
http://www.ebay.co.uk/itm/TK103-A-M...cessories_Safety_Security&hash=item3f26c72910
I've linked the tracker to one of the alarm outputs that issue a 12v signal when the alarm sounds. actually, it might have been a -12v signal, I can't recall. Anyways, what that achieves is being able to set the car alarm to silent alert (you can leave the alarm sounding if you prefer it makes a noise but not great for your other marina folk if you get false alarms) so i receive a txt if the alarm goes off. I can then call the marina staff to go round to the boat and hopefully catch them in the act
