PabloPicasso
Can you give mendetails of what and where you oredered your chinaspacher from please.The Vevor 5 kw fits straight into a Webasto EVO 3900. Bracket and all. Most Chinese heaters appear to be pretty much identical, apart from the different housing colours and the control unit.
Some of the chinese control units can be programmed in their operating parametres, such as pump frequency, fan speed, etc. Mine does not do this and it has not been needed. The access code, if your controller happens to have this feature, is 1688.
The newer controls may have an App function that allows you to operate the heater from your phone. I really have no idea why I would need that.
I tried adapting/using the Webasto cabel as well - it works for communication lines, but the power supply requires a heavier gauge.
All in all, it took me 30 min to do the switch while at anchor up some wet and cold Scottish loch in the highlands. It started at first try, still does, and after ran, pretty much, for two months straight. After an almost 12 month hiatus, it started up again at the first attempt. Out of interest and to see if the original Webasto pump was any quieter, I looked inside and there wasn't even a speck of soot. As stated, it doesn't work with the Webasto pump, but the Web's rubber harness made a remarkable difference to the ticking sound.
Here in Brittany, the local suppliers want 2800 Euro for a new 4 kw Webasto ... a 5 kw Vevor can currently be had for 84.- Euro.
As I am writing this from the comfort of my v-berth, I can barely hear the chinese replacement humming away to take the morning chill out of the cabin.
Best, A.
I'll send a PM
