KevinT1
We have a Webasto Airtop HL32 fitted to Catre - installed in the engine compartment when built by Hallberg Rassy. When I bought Catre 5 years ago the Webasto struggled to fire and I stripped it down and rebuilt using all new gaskets plus the burner ( all genuine Webasto parts ).
I've suspected for the last few months that it has been giving off a smell when operating. I don't think is coming from the heated air distributed around the boat - and this has now been proven after fitting an additional outlet into the heads. The heads are pretty much sealed off from the rest of the boat when the door is shut and although the heater outlet was pumping out hot air there wasn't the smell that I have noticed elsewhere.
I'm concerned that this could be exhaust gas - but cannot identify any leaks in the exhaust pipe, and as such are not using the heater at all now.
I've got both a Neureus CO sensor and a seperate one - neither are alarming, and I know that I've got a very sensitive sense of smell ( my wife cannot smell it ) but stupid question - do diesel exhaust fumes smell ? and would they always contain Carbon Monoxide.
The only air movement I can detect is coming out of the end plates of the heater - it's cold and I assume from the pressure side of the clean air
Any suggestions on where it might be leaking and / or how to check for leaks on the exhaust side - I'm considering removing the exhaust pipe from the webasto end, blocking the outboard end and pressurising with the dinghy inflator pump then seeing if the pressure falls
thx, Kevin
thx, Kevin
