Robin
To update after earlier posts, I have now tried Mscan Pro and yippee can receive faxes OK. Also received RTTY OK on Mscan as well as SeaTTY and JVComm software. I still cannot receive Fax via JVComm, the problem I believe is the 'slant' correction which I haven't been able to do as JVComm suggests, the Mscan software is much easier to do this on and results were instant.
Mscan Pro is pricey at around $195 to register and remove the banners they put over the screen inviting you to register. They have a basic Mscan program without RTTY and Navtex at $99 which might be my choice in combination with SeaTTY
SeaTTY seems excellent for RTTY/Navtex and costs $35 only to register
JVComm receives RTTY OK and if I could crack the 'slant' configuration problem this program would be OK and it is not too expensive to register especially as it covers Fax/Weathersat/RTTY and Navtex in one package. I will try and config this with data from Mscan and see if that works.
