Weather School Musing...Ups and Downs of the Jet Stream
simonjk
6 Mar 2003
www.sailingweather.co.uk
Hello,
Turmoil at Westminster seems to be matched only by turmoil in the atmosphere this month.
I’ve also posted a version of this musing as a PDF file for you to print at http://www.weatherweb.net/WeatherSchoolMusingUpsandDownsoftheJetStream.pdf
June started off with sunny skies and warm temperatures, but since the weekend we have drifted back into more unsettled conditions. Many people have been asking me why this should be, and you won’t be surprised to learn the cause is that old chestnut; the jet stream!
Let’s look at the 500mb chart for midday last Monday, 1st June 2009. Now, what this chart shows is the actual height of the 500mb level in decametres (the solid lines). For example ‘560’ means that the height of the 500mb surface at that point is 5600 metres. The closer together the solid lines (or the ‘height lines’) the stronger the winds at that level. Also on the chart are dash coloured lines, and these are temperatures is 5C steps.
Temperatures is important because the warmer the temperatures, the higher the height of the 500mb level and vice-versa.
On the PDF file I’ve marked on the jet stream as the thick, dashed, blue line. Notice how it meanders in an ‘n’ shape over the country. This is the classic hallmark of high pressure over the UK. As warm air is pumped northwards over the country the 500mb height builds. This increase the amount of air above the surface of the earth at that point, hence pressure builds and on a surface chart high pressure would be shown over the UK on this day.
Compare this with the 500mb chart for last Sunday. See how much further south of the country the jet stream is. It is blowing through Portugal, Spain and the up through southern parts of central Europe. This has meant that the low pressure areas which are hooked-up by the jet stream and blown along by them, are to the south of the country, hence the reason for southern areas seeing most rain.
At this time of year the jet stream should be much further north, between Iceland and Scotland and that is what we will have to see before the weather improves.
However, the forecast chart for the weekend (PDF bottom right) is showing a weak ‘n’ trying to build (this is a ridge) and so on Saturday conditions may become warmer and drier over most of the country.
Hope that's useful.
Simon
Have you got a view on how the Enso conditions affect this??
At the last report that I saw the Enso conditions were becoming neutral, and this would settle things down for us this summer.... as apparently the La Nina conditons of the last 2 years had a bad effect (From our perspective) on the North Atlantic Oscilation.....
Thanks Simon, if it is these streams of jets causing the problems, can't we just phone up Air Traffic Contol and ask them to route them a bit further north?
Thanks Simon.
The jet streams position in the latter half of the week looks to me like summer last year - constant stream of lows delievered on to us by the bloody thing.
Are we in for another long term delivery again ?
