dje67
In support of the Pilothouse!
As an Evasion owner, I can vouch for the flexibility that the Pilothouse arrangement offers. As mentioned earlier, the inside steering postion is not used that often, but when I do use it, it is for good weather-related reasons. If I don't have full wet-weather gear on, being able to nip below whilst a shower passes is great. Also, if sailing with crew and it is wet, everyone can go into the warmth inside, without leaving the poor helmsman on his(her) own outside.
I've often sailed her from inside as well and can see all the sails through the Evasion's sunroof, including the wind indicator. I might not get the optimum sail adjustment, though, because I would slightly over-sheet the sails meaning that small wind direction changes don't leave the sails flogging. All sail adjustments are immediately outside the cabin door, so adjustment is actually no problem.
Combine a pilothouse with a warm-air heating system and you've got a lovely balance between helming outside as normal against keeping warm and dry if required. The main cabin table also allows charts to be viewed from the helm which is good.
My evasion was also used a race committee boat on one particularly foul evening - it beat the pant off other boats because all the race paperwork, binoculars, race information etc. etc. could all be laid out in the warm and dry whilst watching the race progress from inside...lovely!
Hi All
I'm very interested in starting sailing. One thing puzzles me however. Sailing yachts, even larger ones have no way of steering them from inside. So, whatever the weather, it seems the helmsman must sit outside in the wind and spray at all times.
In any other mode of transport you can sit inside out of the weather.
You wouldn't drive around in an open car in the rain would you!
Aircraft originally had open cockpits, but they reverted to enclosed some time in the 1930's I think.
Is it because yachting clothing manufacturers want to make a lot of money selling protective gear?
