lenseman
- Joined
- 3 Jun 2006
- Messages
- 7,077
- Location
- South East Coast - United Kingdom
I belive you can mix white spirit and parrafin wax to do the same thing
Yup
WD-40 is just a con.
WD-40 is just a con.![]()
I thought WD 40, stood for War Department, well the WD bit anyways. No idea about the 40......
I rather doubt it, unless you have a very old can! The propellant in WD40 is carbon dioxide these days - very unlikely to help start an engine.
I always thought it was the 50% paraffin which did it
. . . . . and Corrosion Blocker. . . . . . .
When I looked up the ACF50 website, it seems to mention 2 products- ACF 50 and Corrosion Blocker. Are they 2 different products to be used in different circumstances?
For corrosion blocker the answer is easy. Anything that will prevent oxygen and or water getting to the metal.
Think oil, grease, Vaseline and petroleum jelly or in some instances a vacuum.![]()
A better solution to protect electrics/electronics is ACF-50, a more recent and more advanced water displacer.
Is there any possibility that spraying WD40 on the back of the electric panel could give rise to an electrical short?
