Zing
I need to fix my bilge alarm system. The failures are wiring connections between the float switches and the wire running back to the controller. 4 connections have failed. Two are soldered joints inside adhesive lined heat shrink and two are in RayTech gel filled junction boxes, supposedly IP68 rated. In all cases water from bilge leaks has tracked along the wires and corroded the thin signal wires to the point of failure. What I have ought to be OK, but it isn’t, so I’d like a bullet proof, reliable solution. Any suggestions?
