penberth3
...I've often thought of but not got round to a cut out that disconnects the water pump after 20 mins continuously running. Anyone know of such a black box?...
Just wait for it to burn out or sieze?
I shall add it to my mental inventory of boat noises....
A/C cooling (with stream of water)
A/C not cooling (no stream of water)
TV inverter fan
Shower sump pump
Galley fridge
Cockpit fridge
Domestic water pump (pumping water)
Forward bilge (fortunately not heard that one in the night yet)
Aft bilge (ditto)
Wife's fan
Eberspacher
Plus of course the noises from neighbouring boats! ....
Etc
Why on earth is your Eberspacher running??
But, actually, the most inconvenient noise at night on a boat is the "slap and tickle" that you get in the bow cabin.
I think you all know what I mean.
For me, thats the main attraction of a mid or aft cabin - no "slap and tickle".
Yup, agree with others re water pump. I've often thought of but not got round to a cut out that disconnects the water pump after 20 mins continuously running. Anyone know of such a black box? Probably eBayable
Main noise for me on dead still night is mullet sucking at the hull. But with a larger boat/more cabins, pumps, condensate sumps etc, there is something buzzing every ten mins on a "quiet" night.![]()
Incidentally, I was awoken from my slumber at around 7am by a scraping noise the other day. Looked out my port hole and there was a chap scraping mussels off the pontoon floats. Presumably to eat or to sell? He could have got quite a meal if he'd scraped the ones off some of our neighbouring boats.
Blimey, are plastic hulls THAT bad?Main noise for me on dead still night is mullet sucking at the hull.
Ah, that's the advantage of Outdrives!
But I'm lead to believe that in SCM you can hear the muscles chomping away at the weed on the bottom of your boat! Not had that one yet.
Too late now, member of F.S. clubBlimey, are plastic hulls THAT bad?
I already noticed that the wave slapping sound is day and night compared to timber boats (and I mean it - like 100 vs. 1 difference!).
But sucking mullets... Pah, frozen snot boats...![]()
Thanks J, but I must say I'm struggling to see that the thing you linked to does the job. Instructions are a bit hard to follow:I had a flood last year when a guest left the bidet valve on the WC turned on.
It is on my todo list .... to add something that alarms when the pump has been running for longer than xx minutes.
This is very simple.
One of these
https://www.ebay.co.uk/itm/DC-5V-12...var=601189261430&_trksid=p2057872.m2749.l2649
And a buzzer ( mounted wherever). Some Fairlines ( an I have not actually looked if mine does) have the switch light up on the lower helm when the pump is running - so a simple place to mount it.
The balance of course is how long you set it for. Most showers etc are probably less than 5 mins - so 5 min is a starting point .
A bit of a pain when you open all the taps to drain the system but you can always put a switch in the buzzer circuit.
The challenge with turning the pump off is that in the middle of a 6 minute shower it goes off and then you need to reset it. Not rocket science of course but has the opportunity to be annoying whereas a buzzer is just irritating !
At £1500 per pump, that isn't the most thrifty of suggestionsJust wait for it to burn out or sieze?
Ref the 6 minute shower there shouldn't be a problem: if your pump and accumulator are well sized the pump will not run continuously even if a couple of showers are in use. The pump should cycle on and off. Each time it cycles on the black box should restart the clock (and I would make it 10 mins anyway).
Mon. Mode:
1. The module Power-on, When triggered the relay is switched on, timer delay off.
2. When triggered on the delay process, again triggered, it will immediately interrupt the delay.
Cycle Mode:
1. The module Power-on, When triggered the relay is switched on, (T1) timer delay off. (T2) timer delay
on. Such cycle. T1 and T2 are set by two adjustable resistors, respectively.
If the pump cycles on and off surely it will never hit the 10 min time setting, which defeats the problem that J is trying to solve?
that was my initial thought Pete, but J wants the pump to stop when tank is empty in which case pressure is never up to the point of pump cycling, so pump is constantly on. It will work fine, although it's probably smarter to have a system drop the breaker when NMEA2K bus gets a message that fresh water tank is down to 3% (say)
cheers
V.
The problem I'm trying to solve is continuous pump running which only happens when water tank is drained. E.g. You put dishwasher and washing machine on with (by mistake) only 1/8th tank of water and leave the boat for the dayIf the pump cycles on and off surely it will never hit the 10 min time setting, which defeats the problem that J is trying to solve?
yup, exactly. Bit of a 1st world prob of course.that was my initial thought Pete, but J wants the pump to stop when tank is empty in which case pressure is never up to the point of pump cycling, so pump is constantly on. It will work fine, although it's probably smarter to have a system drop the breaker when NMEA2K bus gets a message that fresh water tank is down to 3% (say)
cheers
V.
