DoubleEnder
I have a hollow, spruce mast, which is 50 feet long. The VHF antenna cable is routed internally. It mostly goes through the hollow centre but is routed in at the points where the mast is blocked for the spreaders. The cable has been tested end to end , and it is intact and undamaged.
However, the very top end of the cable has suffered damage and there is now only a very short length emerging from the mast, maybe 2 inches. I am looking for the best and tidiest way to make a really waterproof connection between this and the length of cable that is attached to the antenna itself. Ideally this connection should be ‘undoable’ but if I could be very certain about its integrity I would accept a permanent join.
To complicate things further, the standing rigging (shrouds, backstay, jumpers and diamonds) is attached by dropping spliced wire eyes over the top of the mast. This means that the wire stays form a very acute angle with the mast and there is limited room for any fitting, between the wood and the wire.
It would be mind bendingly expensive to replace the cable in the mast, just to get another foot of length at the top, so that isn’t an option. And I will not lead the antenna cable up the backstay! So it’s a join at the top, or recommendations for a very good hand held VHF.
One idea would be to use standard fittings to make the join (ideally made of solid gold hehe) , then slide the whole thing into a piece of hose, which I could fill with Sikaflex. But that‘s sh1t or bust approach, which I’d prefer to avoid.
Any good ideas?
thank you
Any good ideas?
thank you
