gusboy
Hi. I own a Birchwood 25 cruiser fitted with a Watermota Sea Panther diesel engine. This engine runs okay but it is nearly impossible to start. I've had the compression tested which was 295psi, for three cylinders with one at 245psi. I've had the injectors and injector pump tested and all were found to be operating as they should. I have two questions, any advice on starting the engine and secondly, what alternative engine would be the best replacement with the minimum of work.
