mick
I’ve finished the season with the boat out of the water and a full freshwater tank. Any reason why I can’t just leave it? Freezing is unlikely to be an issue.
I had drained the system , but didn't drain the calorifier.
If you have a calorifier, it may still be full when your main tank is dry. I have to crack open the relief valve on the calorifier, attach a hose to the fresh water system and siphon it out. (Not forgetting to prevent air entering by closing the taps at the sinks!)
If air doesn't get in from somewhere, how's the water going to get out?
I have topped up my water tank - but my boat is on the south coast and I visit it once a week. (I like to make a cup of tea....)
Freezing is the only risk . I assume your boats location is not liable to significant frost.I’ve finished the season with the boat out of the water and a full freshwater tank. Any reason why I can’t just leave it? Freezing is unlikely to be an issue.
Even if freezing was impossible (not just unlikely), I would take fall as an opportunity to pump the tank down, clean a little, and pump DRY. In that way it will not be nasty when you come back.
You don't put glasses away dirty in the kitchen. You put them away clean.
