ColourfulOwl
Active Member
This is my first winter of owning a sailing boat, I've decided to keep mine afloat as I want to use her as much as I can. I don't currently liveaboard but am in the process of making changes to the boat to become one.
When I went to the boat last weekend the water pump had become un-primed. After faffing about I figured out how to get the pump to prime on my boat. In the process of figuring it out, I took a look at the pre-filter (if you can call it that) for the pump. I noticed there was a small amount of sediment in the mesh and a weird film like substance (I'm guessing lime scale) sat on top of the water that was in the bottom of the filter. This has sort of flagged up to me that I need to look at sorting out a proper filtration system for my fresh water.
From a filtration perspective I have a good idea as to what I want to do. I want to go down the avenue of a full house filtration method with filters after the pump but before the split to the heads / galley.
My question is mostly around purification. What are people using to purify the water? I would rather avoid going down the avenue of chemicals, IE chlorine, and am currently looking at the idea of a UV system. Has anyone got any experience with them? Any recommendations?
