saltlife
New Member
Water pump keeps cutting in. Checked all fittings and found no leaks.
? any surgestions where to look next so I can get a good nights sleep
My boat is fitted with shower sump pump which takes water from the shower & sink, collects it in a box and then, when it triggers the float switch, pumps it overboard. There is a non-return seal in the sump box to stop water draining back in from the pipes. With the fat content in soap & hair shampoo the seal ceases to be effective and allows water to seap back in slowly eventually triggering the pump again, obviously this happens at a time not related to any use of the water system - so it's not simple to track down. The bad news is that the companies that sell the sump trays don't sell the seals separately and a new tray can be £75.00. I bought a Jabsco non-return valve and fitted it on the outlet pipe just after the tray.
