Water Pump Depression
tom52
23 Sep 2001
Is anything more depressing than spending a cold wet winters afternoon lying on your stomach skinning your knuckles replacing the exhorbitantly expensive rubber seal in you raw water pump only to run the engine and find the f***ing thing still drips.
Oh the joys of being a millionaire boat owner.
<hr width=100% size=1>
Yes.
Spending the afternoon getting wet, skinning your knuckles to get the cover off, and then finding you've got the wrong part.
Regards
Richard.
the dreaded shaft prob, was there a score on the shaft? or did we damage the seal when we put it back in? depending on which there are several ways around it
stu
<hr width=100% size=1>http://www.beneteau-owners-association.org.uk
hihi
i have a yanmar too ......do yourself a fav. get a speed seal......!
no leaks......no spanners needed.....easy access.....can change the impeller in about 5 mins!........best 50 quid i ever spent.
regds brian
Thanks for the sympathy chaps.
Its always nice to know you are not alone at times of winter maintenance misery.
The pump is a Jabsco 19mm BRZ 10 Flange fitted to a Volvo MD2020.
I am going back today to try and get it off and bring it back to the comfort of home for a serious look. Although the inaccessibility of two of the bolts means even getting it off might be a mucky struggle !
When I know whether its the shaft or the seal thats b*ggered I'll be back for more advice.
Thanks Perlonius but its the shaft seal not the cover thats leaking.
Also its the dreaded volvo/jabsco combination not a Yanmar.
