Peterlewis321
I replaced my Jabsco Par Max 4 pump a few weeks ago (it failed) and had no choice but to go with a Johnson WPS 3.5 (as that was all the chandlery had) which I must confess seems pretty damn good and much quieter than my previous pump. We also have an accumulator fitted as part of the system and I set the internal pressure just below the cut-in pressure of the pump.
However, I’ve noticed that the pump seems to flicker on/off for maybe a few seconds when it repressurizes the system after a tap has been switched on and subsequently switched off. The only reason I know this is I can see the water pump light on the control panel in the saloon flicker for a few seconds between being fully “on’ and finally going out. I’ve bled the system of air (I think) and to be honest it is causing us no real issues as such, however I just wondered any opinion from this forum-not worth worrying about? Or does it indicate I have something setup wrong? Thanks
