junyer
New Member
any body know why i got water on top of pistons on 1 side of a mercruiser v8 the engine was running slow but firing ok .when i opened the throttle there was a clicking sound and i started to lose powerr.i slowed to about2000 rev and limped home . the engine fired water out of the 4 cylenders with the plugs out the oil is milky under the rocker cover, in the sump there could be a bit of water but it looked like oil not milk.there was a little water in the carb. there is a flap in the exhaust that looks as if there is a bit of rubber worn off the end. when i took the top bit off the manifold the gasket broke (or was it leaking there looked like brown marks on the inside )
