asteven221
When checking the oil level last weekend, I noticed that there is the sign of water in the reverse gear of our boat i.e. milky colour.
I expect that there is a slight leak from the oil cooler which I will need to sort, but does anyone have any advice on removing the water/oil from the gearbox ready for fresh oil refill? Normally I would just suck the oil out from the dipstick tube with an electric pump. I suspect it doesn't remove all the oil which means that it's likely the water will be left at the bottom which I can't get to with the tube.
My ideas are:-
Would running the engine for a few minutes to create a oil/water mixture and then removing it as a combined mixture work?
Or perhaps trying to suck the water from the surface first now that the boat has been idle, with the idea that the water is sitting at the top of the oil.
I could then run the engine to create a mixture of oil and the remaining water and suck that out?
Any better methods?
Incidentally, it's a ZF IRM220.
Also, I am not sure if the drain plug is accessible which might be a better bet, however I am not certain all the fluid will drain. If there is some left then I suspect it will be the water?
As always - any advice much appreciated.
My ideas are:-
Any better methods?
