steve yates
So my new longbow has a yanmar hp30 engine, more or less brand new, less than 100 hrs use, but boat been ashore for last 3 years.
It started up, but soon stopped. Owner had left the deisel tank full, with bug additive added to protect it.
Quandry pumped up some fuel from the bottom of the tank and it was water and brown sludge. Took about 25 litres out before it started to look like red deisel again.
On checking the fuel filters, the primary was black with gunge, and the inside of it's casing, I mean really black, but the secondary was relatively cleanish.
Changed both, the date on the primary filter was oct 2006, so been in there for 10 years, obviously not changed when the new engine was installed.
We bled fuel through till it was running clean before changing the filters. The engine started up after a few attempts, and then ran fine for about the 10 mins we allowed it.
Quandry will pump out another load for me when the tank has had time to settle, and add 20l or so of new deisel.
What is the general opinion on the best way forward with this? I will check the filters again next week when I go up for the lift in, and bring some spares. If they are ok, do I run with it, checking the filters regularly and changing them?
Or do I pump out all the deisel, and refill with fresh, it's a 130l tank.
I'm a bit reluctant to do this, not from cost, as obviously a damaged engine will cost far more, but from fear of what is lying in the tank bottom that emptying out and refilling will stir up, and possibly send into the engine. (disposing of 130l of deisel in ardrishaig may also pose a problem!)
Anyone been there and got the t shirt?
Thx, Steve
Thx, Steve
