mikefleetwood
There was a thread a little while ago polling people's choice of drinking water onboard.
Musketeer has about 180l of "fresh" water (now fitted with gauges so I can see if I'm about to run out!), and I don't want to have to find somewhere to store bottled water. At the moment, the water is only used for hand-wash and to fill the kettle - so boiled before any consumption. At some point we want to be able to make overnight stays, so we will need clean/safe water for drinking, cooking and teeth-cleaning.
I'm looking for recommendations for an inline filter that I can fit after the water pump/accumulator so all fresh water passes through it. I want to make sure any crud that's been sloshing about in the bottom of the tanks for the last 40 years isn't going to poison us. There is a small strainer before the water pump, so that should remove any glass fibre bits from drilling holes for the gauge senders.
Thanks.
Thanks.
