Heckler
My thru hull had a reducer which crumbled! Luckily on the hard!Yes, a common method on Beneteau motorboats. The grill is shaped to act as a scoop although you still need to burp the seal to eliminate an airlock. Do check that thru hull though. The hose tail on the ball valve was brass, as fitted by Beneteau, and with only light pressure it crumbled (seriously dezinced) and water started to pour in. My natural reaction was to shut the ball valve but the water continued to pour in! I then realised that ball valve was of no value at all as the water was coming the other way from the prop tube. Luckily I was on board but if this hose tail had failed when I was not, even if the ball valve was closed, the boat could have sunk.
Www.solocoastalsailing.co.uk
