noswellplease
More sickening experiences when considerable water discovered in bilges during long passage when lack of wind dictated engine only. The boat is a long keeler where the rudder and prop are in close proximity.Anyway not being a marine whiz it appears to me that water is is being driven up the upper connecting tube which houses the rudder shaft and simply spills out at the top of the tube and into to the aft storage locker where it drains back down to the bilges. I noticed the previous owner had put some silicon around the top to this shaft housing but I guess the proper solution is not to be found in a tube of silicon.Without the engine running everything appears to be ok and no water in.
If anyone has any experience of this problem I would be interested in their solutions. I suppose the answer won't be cheap? Now that would be a first! Russ
