Is it more fun than watching paint (or nth coat of varnish) dry?I went to replace the snap carabiners that we use on the davit wires to hoist our tender up. I went to tighten the shackle and this happened. A reminder not to ignore rust staining.
It would’ve been more exciting had our dinghy fallen off the davits when we were mid-Atlantic! But not the excitement we were looking for.Is it more fun than watching paint (or nth coat of varnish) dry?
Looking at the way the bolt has failed, I wonder if the cause was sea water trapped between the two faces of the thread - over a period of some years?I went to replace the snap carabiners that we use on the davit wires to hoist our tender up. I went to tighten the shackle and this happened. A reminder not to ignore rust staining. It isn’t always merely cosmetic.
Quite likely. I might try some sealant/thread lock to keep the water out.Looking at the way the bolt has failed, I wonder if the cause was sea water trapped between the two faces of the thread - over a period of some years?
What's wrong with that? Any RN Dockyard would fix that with some super glue.I had alittle Macwester double ended and found after a year the stainlesssteel machine screws holding on the rudder where actually just the heads holding on by a thin film of metal with the core completely gone
I would be more worried about the 1858 lead line surveys! (-;
The coral has probably grown a bit since then….!Thanks for posting. It is indeed easy to dismiss as light staining, just surface discolouration.
Except they weren’t.Looks like the shackles and clips Lidl sell
Like wot they fix the aircraft carriers
