Was in my lifestyle guru's emporium earlier today-
Was in my lifestyle guru\'s emporium earlier today-
yes, that's right, B&Q.
They are selling two stroke generators at £99.98 a throw but nowhere can you get any info as to the waveform of the output. The only quoted figure is 720watts continuous (and I surmise by the model number, 980watts intermittent) Probably not a suitable output to run a battery charger but probably OK for power tools or lighting to antifoul by. 3hrs duration per fill-up.
Just for info.
Steve Cronin
<hr width=100% size=1>The above is, like any other post here, only a personal opinion
snowleopard
Oxford
Re: Was in my lifestyle guru\'s emporium earlier today-
an alternator is likely to produce something pretty close to a sine wave. it's only cheap inverters that put out square wave.
more important is the frequency/voltage regulation which is likely to be a bit suspect in a cheap genny.
maxi
8 Nov 2002
Hampshire
£50 at Makro, although you will be an old man by the time you get through their checkout.
