lumphammer
This weekend I have just noticed that my ignition warning light is glowing, even though the ignition is switched off and the engine battery is switched off.
I have a Sterling alternator to battery charger and a 20A mains charger. The engine and domestic batteries are not connected, except through the earth.
Initially I found that if I switched off the battery charger and left the domestic batteries on, the light would go out, but by the end of the weekend it didn't make any difference what was on. I could isolate all the batteries and just run off the battery charger, or switch off battery charger and run off batteries the ignition light still stays on.
As I understand it, with the engine off, one side of the warning light is effectively grounded through the alternator. With the engine battery isolated the only way 12v can get to the lamp would be through the A- to - B charger.
Any suggestions or thoughts on fault diagnosis gratefully received
