Warm air circulation
Poignard
23 Jul 2005
South London
I have a Taylor's heater installed amidships in part of the coat locker, opposite the heads.
It generates a lot of heat but I would like this heat to be more evenly distributed around the saloon. I have being thinking of fitting one or two low wattage fans into the plywood main bulkhead to draw some of the warm air out of the coat locker.
Any suggestions? Big slow running fans or small high speed ones? And does anyone know where I could buy those directional outlets we used to call 'punkah louvres' in the Navy?
Scotty_Tradewind
31 Oct 2005
Me: South Oxfordshire. Boat, Galicia NW Spain
I've seen a 29 footer with a couple of small computer fans (Maplin) running from a charcoal heater (in similar position to your Taylors), via plasic drainpipe through lower lockers, with one outlet by chart table/nav area and one in forepeak.
Success unknown.
I have a water pipe system/heat exchanger running off an Eberspacher with 2 matrix+fans to send heat to saloon and forepeak. Trouble is with fans you tend to feel a cool draught somewhere as heat disperses.
Advise keeping it simple.
Punkah Wallah?
Poignard
23 Jul 2005
South London
Success unknown.
Punkah Walla?
That's a clever idea, if a bit too complex for my boat.
'Punkah louvres' (RN style) are similar to those things on airliners that direct an icy blast of air on your head, but larger.
I should have looked on Google. Here's what I mean
http://www.rcmproducts.co.uk/downloads/Grilles/PKL_Punkah_Louvres_Grilles.pdf
Gordonmc
19 Sep 2001
Loch Riddon for Summer
Have you thought about an Eco Fan?
They are designed to sit on top of a wood-burning stove to distribute the hot-spots around a space.
Heat is used by a thermoelectric motor to drive the fan, so no power draw.
Scotty_Tradewind
31 Oct 2005
alahol2
22 Apr 2004
Portchester, Solent
www.troppo.co.uk
On a previous boat I had something like this mounted directly above the heater. Without the fan the temperature would rise and create a 'fug' at the deckhead. It would then gradually creep lower until, maybe an hour later, it reached foot level. When using the fan the heating was much more evenly spread around the whole cabin.
Poignard
23 Jul 2005
South London
Yes that would probably do, and be easy to install, but what I like about the computer fans is that they are so quiet and don't use much electricity.
NormanS
10 Nov 2008
The outlet fittings for Eberspacher ducting have rotateable louvres. Perhaps one of them mounted through the bulkhead, with a computer type fan attached would serve?
Poignard
23 Jul 2005
South London
Yes, that's the sort of thing I had in mind but I didn't know Eberspachers had those, never having seen one. Thanks for the good idea.
Richard10002
17 Mar 2006
Manchester
The narrowboat community isn't sure that these things work. There is a body of opinion, both for and against.
Having joined them, and having inherited an Eco fan with the boat, I'm on the fence. It's busy spinning away, obviously powered by the heat from the stove but, if I hold my hand a couple of inches away from it, all I feel is a light, and cool'ish breeze. Hold my hand a foot away, and I feel nothing. The thick metal blades that the air is drawn over are too hot to touch more than briefly, so there's a fair amount of heat to be drawn upon.
On the sofa, about 3 feet away, I'm warm and toasty. In the kitchen about 12 feet away, it's warm. In the bedroom, separated by an alley with no door, about 25 feet away, it's relatively cool.
I wouldn't spend the best part of a hundred quid on one based on my experience to date.
