bradleyscott596@yahoo.co.
See above
What's the daft of your 8m boat? Much over 2'/60cm and I suspect that most of the canal network will be too shallow for it and few boats with less draft than that are suited to an open water passage from Newhaven to the Thames.
Hi thanks for replying . It,s draft is 0.97 metres and it,s air draft is 2.44 metres ( whatever that is !? ) . Its a Norfol Knights Kent and i just bought it . I have zero experience so want to stay on canals before i set off on a world cruise !!!! . Would most appreciate any advice . Regards , Brad .What's the daft of your 8m boat? Much over 2'/60cm and I suspect that most of the canal network will be too shallow for it and few boats with less draft than that are suited to an open water passage from Newhaven to the Thames.
Thanks for help , have emailed people you recommended . Much appreciated , Brad .Safest and quickest - by road.
Can it go on a trailer? That would be cheapest
If not there are specialist boat transporters such as Ray Bowern -
http://www.bargemovers.com
Thanks for replying , do you have email address of Shipleys ? . Much appreciate help - this is all new to me , BradSuggest try Shipley transporting ; they are a sort of Broker who have other Transport companies on their books whom they put out all the enquiries made about transporting ; might mention that the longer you give for the job to be done the better the quotes will be (ie the transport companies can work your job in with other jobs on their books ; much will depend upon the craft keel specification etc : ie a bilge keel might fit onto a low loader with a lift on board
Shiply: The Transport Marketplace - Get Delivery QuotesThanks for replying . Do you have email adress for Shipleys ? . Muchappreciate advice - this is all new too me , Brad .
I am afraid that boat is totally unsuitable for the canals. It is a seagoing sailing boat and is far to wide and high for the canal system. If you want to use the canals then buy a canal boat. Pottering on the canals is not a good basis for learning how to sail a boat such as you have bought.Hi thanks for replying . It,s draft is 0.97 metres and it,s air draft is 2.44 metres ( whatever that is !? ) . Its a Norfol Knights Kent and i just bought it . I have zero experience so want to stay on canals before i set off on a world cruise !!!! . Would most appreciate any advice . Regards , Brad .
It's worth pointing out that any boat on the inland waterways needs a "BSS" safety certificate and that can be difficult / expensive to obtain. Plus as Tranona points out a boat like that doesn't really work well on canals - the wrong shape.I am afraid that boat is totally unsuitable for the canals. It is a seagoing sailing boat and is far to wide and high for the canal system. If you want to use the canals then buy a canal boat. Pottering on the canals is not a good basis for learning how to sail a boat such as you have bought.
Suggests you take a course on learning to sail yachts before even thinking about going to sea. Your boat is quite capable of coastal passages, but you need to find out what is involved, not least finding somewhere suitable to moor it.
With a 3ft + draught you may be better heading for the upper Thames rather than canals.
I gather you will be using her as a motor boat rather than sailing.
Just found the boat advert on Ebay. Needs some work but was well set up once with Radar, self tailing winches, liferaft, etc.
As said above would make a nice coastal hopper, from Newhaven you've got Brighton, Eastbourne, Shoreham. Not the most interesting coastline but fine for learning.
