Wake speed
boats produce different sorts of waves (height, steepness, wavelength between crests, etc) and these variations influence the speed and angle at which the waves move away from the centreline of the wake. Empirically, you can see how the shallowness of the water also changes the normal shape and angle of the boat's wake as the reflected pressure waves change the angle and depth at which the boat moves (known as "squat").
Generally the angle at which wakes waves move away from the wake centreline starts at just under 20 degrees, so there is a geometrical relationship with the boat speed . Waves with greater distances between crests (wavelength) travel faster than short ones, so the longer (bigger) waves move away faster than small waves.
[/IMG]
sometimes the packets disperse, sometimes they don't. There's more physics in that than I can deal with on a Sunday morning :)
The speed of a wave is proportional to the square root of the wavelength. I was amused by a comment in Tracey Edwards's book about her RTW race that 'waves travel at 22 knots'. A ripple on a pond might do 1 knot, a tsunami typically hundreds of knots.
Here's a formula: http://hyperphysics.phy-astr.gsu.edu/hbase/waves/watwav2.html Note that the depth factor is insignificant once the depth is more than a few wavelengths.
[/IMG]
Which is presumably why the wake itself in your photo appears curved, as the waves flatten out and lengthen, they actually speed up. I wonder what would happen in an infinite lake. Would a boat's wake eventually overtake the boat?
depends if the boat speed is greater than the theoretical speed of the wavelength of the big waves. But by they time they are catching up, the crest height will be very small, as the energy of the boat is dispersed over an ever lager area. (Ooops. "larger", of course !)
I believe that some tsunami waves travel at extremely high speeds. In my infinite lake, I am supposing that the wake waves would increase in wavelength until they approach this level. Maybe.
