halcyon
Perhaps the most technically correct solution is a B2B charger to float charge the engine battery.
This avoids overcharging the engine battery, which has much less drain on it than the house battery.
An emergency starting link covers the possibility of the engine battery failing. But kept isolated and properly float charged, it's likely to last over ten years.
You cannot overcharge an engine battery with a VSR, the over charging was based on standard diode, blocking diode systems using alternator sensing on service battery. The idea was on high loads the diodes would drop around 1.2 volts, swo the alternator regulates at 15.6 volt to maintain 14.4 volt at service battery terminal. Now the engine battery is little discharged so quickly reaches recharge and current falls, so does volt drop across the diode to around 0.7 volt. So 15.6 charge voltage minus 0.7 volt drop in engine diode equals 14 9 volt charge voltage to engine battery.
Well that was the marketing theory behind it, but a good VSR will only drop 0.04 volt per 100 amp, so at 1 amp very low.
rian
