pvb
That's the point, it indicates what is supplying the power for the winch, alternator or which battery / batteries.
So if the voltage is the same, because the VSR is connecting, what exactly indicates what's supplying the power?
Brian
I think I would always power winch from engine battery on the basis that engine will be charging when winching.
The point is the batteries are only connected by a VSR and wiring which will have a finite resistance. This resistance is not normally noticed until you draw a large current from the system (when winch is working hard). So simplistically if winch power comes initially from house battery then its voltage will drop somewhat lower than that of the engine battery. Perhaps just a fraction of a volt. If the engine alternator is charging at a decent lick and if power comes initially from house battery we would expect the alternator to be trying to maintain voltage of house battery meaning a large current from alternator (to engine battery) then to house battery via VSR hence possibly blowing fuse. I think I would always power winch from engine battery on the basis that engine will be charging when winching. olewill
hm, 'is alternator output collapsing'
so could the alternator be able to supply power for a short amount of time and then decrease power even thought it is needed ?
this a sign of it wearing out ? or the belt slipping, it does not squeak / produce dust.
how would i test for that ?
Does not seem high to me. Connections must be able to take the full charging current and VSR are often rated at 70A or more. Not sure a dedicated fuse for the VSR is needed, provided there is a fuse close to the house bank.
k, 'You need data, in your case volts, unless you have a clamp ammeter'
which i now do have. and a remote for the windlass so i can run it and see the amps produced at the same time.
'So for a 700W windlass (guess), you might guess a surge current of maybe 200A'
yes agree, but the fuse blew when winding in 30m relatively easy, vs coming to a complete stop on a knot in the chain which would draw a major amount of amps for a sec ?
It is an absolute must. Without it a heavy load can be applied to the VSR and its wiring, damaging the VSR or the wiring, even resulting in a fire.
That is completely understood, Paul, but why do all the VSR wiring diagrams show a fuse on BOTH sides of the VSR? Surely just one will protect the VSR.
www.solocoastalsailing.co.uk
