psousa
Hi all!
After long time having cold-start issues, decided to learn about and DIY glow plugs test and replace.
So, removed 2 of them, tested it's resistence (both failed) and tested them by direct connect to a battery (both failed too, as expected).
The 3rd one is blocked by something related with the injection system (see the picture). This part have a hose connecting to the top of the diesel filter and, in the other side, to the injectors, so I suppose it is the injection pump or something. I'm affraid to be messing around with this part. The only thing I touch in diesel circuit are the both filters (to replace them).
Any way, I've tested this particular glow plug resistence in it's place and failed too, so I would like to replace it too, but I'm affraid.
So, what do you suggest:
1. leave this glow plug untouchable (even knowing it's not working) and replace the other 2 only
2. disconnect that diesel circuit hose and try to remove it and pray to be enough to remove the glow plug (I'm not sure... there is a possibility to continue to be blocked by the hose connection too and I don't know if I can rotate that small 'head' which host the hose connection).
If I decide to disconnect the hose, I will introduce air in the injection circuit AFTER the oil filter and BEFORE the injection. How can we remove this air from circuit? By pumping diesel to circuit using the small pump near the diesel filter (as we do when changing the filter)? Will the air introduced AFTER the diesel filter leave the circuit by doing this procedure?
PS: when I remove glow plugs, they are coal/black dust covered... is it normal?
Many thanks!
Many thanks!
