MoodySabre
For family health reasons I haven't used the boat much this year. The 34 year old engine has always started very well and been trouble free for the last 16 years.
From my marina you have to motor out down a creek less than 0.5nm. I thought the exhaust note was not right (sounded dry) but there appeared to be water from the exhaust (Moody exhausts are just below the waterline). I kept motoring to give her a bit of a run but after 10 mins the oil pressure alarm sounded. I should also say that the rev counter wasn't kicking in but a squirt of WD40 in the key hole seemed to solve that. We went sailing. On return the engine started fine but halfway up the creek the oil alarm went off again. No choice but to continue slowly. Back in my berth I went to check the oil - the engine was VERY hot. The temperature alarm hadn't sounded - yet to check if it even works. The oil level was fine - still looking quite clean (surprised). The coolant level was at Minimum which is usual. The impeller was fine. No weed in the strainer. Went home.
Next day the engine wouldn't turn over (three batteries all fully charged). Checked all the connections. Spanner on the pulley and engine turns. No decompression lever on this engine BTW. Tried the key and it turns over very very slowly. Spoke to local engineer who said the starter needs to come off and be tested before looking for further trouble. Dodgy knee means engineer will do it when he can. He had a quick look and said the thermostat bypass was blocked so this could account for the overheat. No way to tell until the starter is checked and the engine started if it will.
For the first time in 16 years I have lost my trust and think that a nice new engine to end my sailing days would be good. But it would be nice to get through this season cheaply! So what are the chances that this might work out okay? What else should I be looking at?
The events of this year have made me quite philosophical - it is was it is. I go sailing with a friend on his boat.
