eddystone
No engineering aptitude whatsoever but had a poke around engine installation today and have a few questions.
1. My fuel tank (1986 Sadler 32) looks like stainless steel - it could be mild steel but wouldn't it have rusted through by now if it was?
2. As far as I can see the fuel hose comes vertically out of the bottom of the tank with a tap on it (in fact the only fuel cut off); does that not make it more prone to blockage? (It hasn't yet)
3. There is a minor drip from the water pump housing and some deposition around the outside of the housing but water flow out of the exhaust looks good. Is this a case of a) cancel next weekend's plans (finally I can go out, I've got a crew!) and put a new gasket on (probably an hours job for the average PBO forumite but about 3 months head scratching for me before I get an engineer to do the job); or b) just keep an eye on it and fix it in due course?
4. If the valve in the siphon was blocked by salt deposits, it doesn't impede water circulation, just stops it protecting the engine which is not a problem for me as I do always remember to close the inlet seacock when I leave the boat. Is this correct?
