Ian_Edwards
A fellow boat owner has a fault on the dynastart on a MD6A.
The engine turns over, but will not start.
There's a good 12 volts at the key switch before starting, an no voltage on any of the dynastart terminals.
Turning the engine over, there's about 8 volts on the starter and 8 v and 6v on the other 2 terminals, the dynamo output is getting hot.
Disconnecting the dynamo output, and the engine starts.
It looks like the dynamo output is shorting either through the control box, or (less likely) through the dynastart.
I couldn't get at the silver control box today, it's under the cockpit floor, perhaps tomorrow.
Any ideas on what's wrong?
Can anyone point to a circuit diagram of the silver control box.
Cheers
Ian
Cheers
Ian
