mjf
After the exchanges last week when we were milling around off Cowes before the RYS salute I was able to watch the water gauges more carefully than when blasting about 'at sea'.
Both rise together to 150 then the stbd carries on to 175 before settling out at that.
The port one stays at 150 for a while then lifts to 175 - then drops back occasssionally to 150ish before rising to 175.
Very clearly there is drain off of waste heat to the domestic water system and the saloon demister ring, quite surprised at the number of cycles the 150/175 readings made in 2.0 hrs with no load on the engines to speak off.
