Labhaoise
About to change my impellors this winter as i figure this may not have been done yet despite only 400hrs on the clock but the boat is 8 years old now. On close inspection of the cover it to the impellor housing it appears that the original green volvo engine paint has never been disturbed to the housing thus i would expect they have never been changed.
If any of you there are familiar with the tamp63 set up you know the access to lossen the screws to the impellor cover is restricted by the 2 oil filters as there is only about 4 inches of space to get your screwdriver on the heads of the screws with the filters impeeding.
I would think i would have to remove both filters to gain enough access to the screws. Has anyone every loosen the screws through another method other than removing the filters or is there a tool with a flat head screw driver fitting that may access the screws within the space . i have tried a 1/4" drive but don't have an attachment small enough to fit in the space between oil filter and cover.
Had i the change an impellor at sea/lake i feel that it may be impossible without removing the 2 oil filters.
Also has anyone every pulled a thread on loosen the screws to the cover or damged a screw head while undertaking an impellor service. would it be wise to oder a few replacements incase they don't loosen easily seeing that they appear to have never been distrubed?
