60F
The Oil Coolers for the ZF Gearboxes on the Volvo TAMD61's fitted to my Gosport based Princess 435 were removed at the end of last week for checking as when the stern tubes were repacked the engineer noted the pipework from the oil coolers to the stern tubes showed some corrosion worthy of further investigation. When he removed the coolers, there was evidence of corrosion / silt inside the oil coolers which would prevent them working properly, There is no obvious evidence of an oil leak (I understand that the gearboxes work at very high pressures and would quickly empty themselves of oil if there was a leak) but they really need to be checked over and, ideally cleaned out and rebuilt or, if absolutely necessary, replaced. I understand the engines ceased production in 1995 and are obsolete and it's difficult to get non routine spares for, so replacing them might be both difficult and costly and so best avoided if at all possible.
Does anyone have experience of these coolers and know if they can generally be rebuilt and, if so, where the best place on the South Coast to take them would be, or whether it is better to replace them and in which case where it might be possible to get either Volvo or pattern parts ( I'm guessing that there was a good chance that Volvo didn't actually make the originals in the first place but fitted a standard part to their engines which may be common to others). As ever, it is quite important to resolve this quickly as the boat was due to go back in the water on Wednesday (though not now
), and although I can do routine maintenance my mechanical ability for sorting this is limited at the best of times !
Any help or guidance would be very much appreciated please.
