LP1
The timing chain cover is salt water leaking from the pump. As I suggested earlier, remove pump, clean up cover, etch prime and paint. Slightest weep from the hose connections causes the corrosion. Also worth changing the seals in the pump while you have it out.
Will do, thanks.
